problem with tag in active campaign
As per the Active campaign's API documentation users can only fetch 100 tags. For a better understanding, you can refer to their documentation.
Although you can get all the tags with the help of the "Get Tags" action event individually.
rsieber
Well, that is not my problem. Please refer to my initial post.
I have the ID of the Tag. So I can use mapping. But if I change the tag ID it is not saved. That is the problem.
Robert
Yes, for that we checked your video after setting the Tag ID you need to press the "Save" button on the action step as shown in the previously shared video.
