Problem with Text Formatter
Status: Closed · Asked by fisto on · 0 views
I am getting an error when trying to parse text.
Pabbly is supposed to parse the text between but it isn't working. Please help.
Task History link: https://connect.pabbly.com/task/history/0?filter_status=applied&filter_by_workflow_id=IjU3NjUwNTZmMDYzMDA0Mzc1MjZjNTUzMDUxMzIi_pc&per_page=20#
Hey @fisto
Please mention the step number in which you are getting the certain error.
Hey @fisto
Upon reviewing your task history ID, it seems that the mapped value within the Text Formatter action step of your workflow does not appear during the live execution from your triggering application.
Consequently, the action step receives no value to parse. Please check the mapped value in your triggering application. Additionally, if you have modified any fields in your application, consider recapturing the webhook response and attempting again.
