Problem with this Workflow and Slack Configuration
Status: Closed · Asked by farrell2006 on · 0 views
Hey @farrell2006
Kindly refer to the help text mentioned in the Channel name field where you have to enter the channel name without any space, so you can use the Replace text action step to replace space with _ underscore.
