Probleme of connection betwwen datepicker of elementor pro form and pabbly
Status: Closed · Asked by Ced74 on · 0 views
Everything is in the title :-).
I've got problem of with the datepicker of elementor pro form and Pabbly.
Whatever I select as my date when I submit my form, Pabbly always gets me today's date.
However, in the Wordpress BO, the date is correct.
Do you have a solution? Thanks
Did you check Pabbly Connect workflow history Which date you are getting from elementor form
I just checked it on my end in my account and my workflow, and it is working fine for me.
