Problems in Calendly integration
Gianlorenzo
I'm trying to set up a filter based on Calendly event name o slug fields, but it seems not to work.
When I look at history i see:
Data out:
Data in:
Whats' wrong with it?
Supreme
Hey @Gianlorenzo
It appears that you have made several attempts to re-execute the activities since the trigger event is a multistep trigger, and the labels vary if you re-execute the tasks again.
As a result, your Calendly trigger step did not get the answer with the time since it was altered after execution.
We advise against running the workflow if it contains the "Calendly" trigger event. As an alternative, pass the Invite in real-time using your appointment page.
