Problems with Crove V.2
Status: Closed · Asked by Garral on · 0 views
Hi. Please, can you solve the problems for the automations with Crove version 2?
Crove team is already working on releasing the version 2 integration in Pabbly Connect. You can directly contact them for any further updates.
Attached is the query I made today to Crove support, and their response. It does not correspond to what you tell me.
We will check with them and shall update you with more information on this.
Ok, Thanks!
Hey @Garral
We have updated Crove's Integration on the platform, kindly reconnect the action step and try again accordingly.
Ok, Thanks!
