Problems with my workflow
Status: Closed · Asked by TSA on · 0 views
TSA — Question ·
Hello, there
Currently I have a problem with my "Bocacy - Meta ads to Google Sheets PTY" workflow, specifically in the step 4, route Panarroller/Joanna. When the lead land in the "BOCACY LEADS - Panarrollers/Joanna" Google Sheet the router does not send the lead to the panarroller Google Sheet neither Joanna Google Sheet.
Can you check this, please?
Hey @TSA
The Counter condition which you have created in your workflow and passing its value to the route was incorrect, though we have corrected it too by manually typing the initial value in the Counter step.
In similar way, you have to manually type the number in your nested routes as well.
Kindly give it a try and let us know if that works for you.
