Q2 for connecting 'Kartra.com to Lulu.com to print when customer orders'
Status: Closed · Asked by 3Awakenings on · 0 views
When setting up the Lulu half of this connection, pabbly shows a long list of fields requiring "Enter text or map data.." (see images)
However, its a complete mystery what these values mean and where I find them.
I saw a similar question asked before in this forum and I reviewed the answer, it explained what some of the fields mean but included no guidance on the relevant data for entering into each field can be found.
NOTE: in the kartra setup step, I was unable to get the 'capture webhook response' to update when i made a
trigger order
Please advise where I find the data to enter into each of these fields
Hey @3Awakenings
Kindly capture your webhook response first then map the desired fields of Lulu.
Meanwhile, you can check out our Youtube Channel for our tutorial video for more integration and many other automation-related videos.
https://www.youtube.com/c/Pabbly/featured
