Questions about Bubble
Status: Open · Asked by Klaziena, Slim Slank Coach on · 0 views
Hi, I have Pabbly Connect. I was trying to find out how to connect Humanbot to Pabbly. Humanbot uses Zapier and not Pabbly. So I am trying if I then connect Humanbot to Zapier to Pabbly in general. So I can use Humanbot in Pabbly. Or is it possible that Humanbot becomes in Pabbly in another way?
Hello @Klaziena,
Could you please share a screenshot of the application you’re using in Zapier This will help us better understand your requirements and assist you more effectively.
Hi Preeti, thank you for your quick reply!
I am not sure what in Zapier is used is the correct one for "Humanbot". When I ask the ai in Zapier I get "Chatbot", see attached screenshot. I just asked it to Humanbot if that is the correct one. Humanbot is this: https://humanbot.io/
Hello @Klaziena,
Currently, we do not have an integration with Human Bot. However, you can submit your request here: https://pabbly.hellonext.co/b/Integration-Request.
Our team will review the request and add the integration if possible. Thank you for your understanding!
I will place the request. Do I receive updates/notifications about the request?
I also something about Bubble. Can you tell me more about that please?
Hello @Klaziena,
You will receive updates on your request directly on the HelloNext platform. However, could you please provide us with the link to the Bubble request you’ve submitted This will allow us to check for any updates and assist you further.
Hi Preeti,
In Zapier I've asked the ai there to create a zap from zapier to pabbly and it came up with the screenshot "bubble in zapier".
On the second screenshot "bubble" you see what I mean in pabbly.
Do I understand correctly that I can use bubble to link it with zapier?
Hello @Klaziena,
Currently, we only offer actions with Bubble.io. Could you please clarify your specific requirements Additionally, we couldn’t find any request from you on HelloNext regarding Bubble.io.
I think we are talking about 2 different "bubble" :)
The "bubble" was suggested in zapier by the ai of zapier and than I looked that up in Pabbly and there is also a "bubble".
No idea if they are the same, but looking at your reply I don't think they are.
I have placed a request for humanbot in pabble connect, see attached screenshot.
The thing that I am trying to get done is that I can get actions in humbot in Pabbly, so I can set the data to other parties, like my contact list in autoresponder. Humanbot only works with zapier. So I was looking a way to get zapier linked to Pabbly.
I have placed a request for humanbot in pabble connect, see attached screenshot.The thing that I am trying to get done is that I can get actions in humbot in Pabbly, so I can set the data to other parties, like my contact list in autoresponder. Humanbot only works with zapier. So I was looking a way to get zapier linked to Pabbly.
Hello @Klaziena,
If you require it urgently you can dm me we'll have free zoom call. I'm an automation freelancer who helps other pabbly users.
Email - [EMAIL][email hidden][/EMAIL]
Hi Himesh,
It would be awesome if you can help me with that.
If you are looking for a way to send data from Pabbly Connect to Zapier, you can try using a Data Forwarder to make that happen.
Thank you but I am looking for a way from sending data from zapier to pabbly
Hello @Klaziena,
In that case, you would need to use a feature similar to the Data Forwarder in Zapier to post data to a Pabbly Connect Webhook. In Pabbly Connect, you can set the trigger as Webhook by Pabbly to receive and process the data efficiently.
