QuickBook Online Custom Fields Not showing in Pabbly
I have created few custom fields in invoice object of quickbook and I have to map those custom field with salesforce fields before creating an invoice. But when I am selecting "Create an invoice" in pabbly all the standard fields of quickbook is comming but custom field are not showing up.
Hello @akankshasingh06
We have escalated this issue to our team, and they are currently exploring the possibilities of adding custom fields to the "Create Invoice" action in QuickBooks.
We will provide you with updates as soon as we receive any further information. Thank you for your patience and understanding.
@Preeti Paryani Thanks for the Update. Hoping to hear ASAP as my client is waiting for the same. Also do pabbly iterate automatically over salesforce product line items for invoice or we need to use iterator for this?
As we receive any updates from our technical team regarding the issue with adding custom fields to the "Create Invoice" beta action, we will notify you immediately.
Regarding the line items, you can use the Data Transformer: Line Itemizer action. To set this up, you need to capture the response from Salesforce in advance format and then map this array response in the "Line Items Array" field of the Line Itemizer action step, as shown in the attached screenshot. This will allow you to handle product line items for invoice creation effectively.
We are pleased to inform you that our team has added an action called "Create an Invoice with Custom Fields" to fulfill your requirement. Please try using it and let us know if it works for you.
@Preeti Paryani Hey, Its highly commendable of getting it done in such a short span of time. Kudos to you guys. But its not working. When I am trying to create invoice by selecting "Create an invoice " its creating in quickbook. But when I am selecting "Create an Invoice with Custom Fields" it giving me error. Can you please look into it and update me asap.
Error:
Res2 Fault Error 0 Message - Request has invalid or unsupported property
Res2 Fault Error 0 Detail - Property Name:failed to parse json object; a property specified is unsupported or invalid
Res2 Fault Error 0 Code - 2010
Res2 Fault Type - ValidationFault
Res2 Time - 2024-12-12T06:03:01.223-08:00
Luv
Active member
Hey @akankshasingh06
It appears that you have turned on the mapping buttons for some fields and you have kept them blank.
Kindly map the details properly then let us know if it works for you.
@Luv I didn't turned any map on. Its still off. Also for your information - when I enter just the name and amount thats is required field in "Create an invoice" than it works fine. But when I enter these two detail with "create an invoice with custom field" option it gives error. The custom field option is build just two days back on request so its possibility that it not working properly. Also it would be great if i could have one meber that is @Preeti Paryani as a point of contact. Its hard to explain the same situtaion multiple time to diffrent person.
Luv
Active member
Kindly allow us some time to look into this issue. We have escalated your concern to the technical team.
Your patience is greatly appreciated.
Hello @akankshasingh06,
Our team has made the necessary changes in the "QuickBooks Online: Create an Invoice with Custom Fields" action, and the class should now be correctly reflected in the invoice. However, there are a few adjustments you need to make in the action step to ensure it executes successfully.
Please note:
  • If you have selected True for the Apply Tax After Discount field, you will need to specify a value for the Discount Percent Based? field (either True or False).
  • Based on the value you enter:
    • If True is selected, enter the Discount Percent (e.g., 20 for a 20% discount).
    • If False is selected, enter the Discount Amount (e.g., 200 for a discount of 200 units).
Please refer to the attached screenshot for further details.
@Preeti Paryani I deleted the action and then I created it again and it worked. Thanks for the solution. Just for your information - Discount Percent Based? field is required field because if we are not entering any value and leving it blank than it give error. So please inform the team to mention it as required field in label.
Thank you for the information. I'll escalate this to the team, and they will take the necessary action.
If you have a moment, please rate us on Google. Your feedback helps us improve.
