Quiero integrar mi aplicacion a Pabbly Connect
Status: Closed · Asked by Albert Sanabria on · 0 views
Hola que tal, espero que esten bien.
Quiero agregar mi app al repertorio de pabbly para que asi mis clientes tambien puedan usarlo, por favor me pueden ayudar con mas informacion sobre los requisitos y el paso a seguir.
Gracias por el apoyo!
La herramienta que quier integrar es esta https://apiwabot.com es mia, y trabaja directamente con la api de whatsapp.
Hey @VinzNetwork
Definitely, you can integrate your own integration of the platform. If you are having development knowledge in API integration and try trying to add the integration to the platform, you can also refer to the following developer guide.
As we have opened our developer platform for everyone. Now, they can also manage their application in Pabbly Connect integration using the developer portal. They will be easily able to update and manage their own app.
Please ask the app team to go through all guides carefully and start working on updates in their app integrations - https://forum.pabbly.com/forums/pabbly-connect-app-integration-guide/
