Razor pay with Aisensy connection issue
Status: Closed · Asked by parmesh272 on · 0 views
Internal serve error face while connecting.
Hey @parmesh272
The internal error is directly coming from the Aisensy, kindly try again by reconnecting your Aisensy account and if the issue still persists then kindly contact their support team for the same.
While sending message through AiSensy Mobile Number required. On that mobile number
-- Mobile number of users with country dial-code to whom the campaign has to be sent e.g. +917428526285.
It means on any one fix number only we can send message, Is it right ?
But what can do if we want to send messages to customer who's mobile no. / data receive in response ?
Hey @parmesh272
For your concern, you need to map the contact in the "Mobile Number" field of AiSensy which will then work dynamically. Kindly try again and let us know if you get stuck at any step.
In AiSensy template we have two parameter email of sender and amount.
I tried with below screenshot 1 and other razor pay parameter also but in whatsapp message we can not get dynamic value
Hey @parmesh272
You can again simply map the email address and the amount from the trigger response to the desired response.
Now all things work fine.
