Re-Capture Webhook Response is not showing anymore
Status: Closed · Asked by Yazan B on · 0 views
Hello Yazan,
Thank you for reaching out.
Could you please confirm whether you created this workflow from scratch or cloned it from an existing workflow?
This information will help us investigate why you're unable to recapture the response from the ClickUp Task Updated trigger.
We look forward to your response.
Thanks and Regards,Preeti Paryani
Customer Success Associate,
note that it was showing this morning after it was disappeared two days ago. but again after 2-3 response applied it is gone
Hello Yazan,
Thanks and Regards,
Hello Yazan,
Thank you for the update and for confirming the behavior.
We have escalated this issue to our technical team for further investigation. They will analyze why the Recapture Webhook Response option for the ClickUp – Task Updated trigger disappears after a few captured responses, even when the workflow is created from scratch or cloned.
We will keep you informed as soon as we receive an update from the team. We appreciate your patience and understanding in the meantime.
Hello Yazan,
Thank you for your patience.
We're happy to inform you that the issue has now been resolved. The Recapture Webhook Response option is now rendering correctly for the ClickUp - Task Updated instant trigger.
Could you please check the workflow from your end and verify whether the Recapture Webhook Response option is now visible and working as expected?
If you still encounter any issues, please let us know, and we'll be happy to assist you further.
