Re-label fields inside Pabbly?
Status: Open · Asked by Pabblynaut on · 0 views
Pabblynaut — Question ·
Say you have 30 fields coming into Pabbly from an external source, and you can't change the source data. Is there a way to re-label the fields inside Pabbly?
An internal "Relabel fields" function? :)
Hrishabh Tiwari — Reply ·
Hello @Pabblynaut,
Unfortunately, it's not possible to directly rename or relabel the fields inside Pabbly once the data is received. Pabbly uses the field names exactly as they are sent by the external app, and those cannot be changed manually.
Let us know if you have any other questions.
Hrishabh
Rate your support
Pabblynaut — Reply ·
Best thing you can do is to use code module for this.
Good idea, I will look into this.
