Receiving two same outputs for one single input
Status: Open · Asked by boton on · 0 views
boton3671 — Question ·
Task History ID: IjU3NjUwNTZjMDYzZTA0MzA1MjY4NTUzMDUxM2E1MTZhNTQzNDBmMzki_pc
Hi guys,
I have been using telegram based text to image generator bots successfully since 2 months. But suddenly for the past 2 hours, I am facing a weird issue. I am getting same image as output twice for each single input. This double outputs error is happening with every work flow. Tried every option, even cloned new workflows, still same error.
Bywex — Reply ·
same , started happening ~ 12h ago or so
noticed it on this workflow
IjU3NjUwNTZkMDYzZjA0MzI1MjZhNTUzNTUxMzQi_pc
Task History ID -
IjU3NjUwNTZjMDYzZTA0MzA1MjY1NTUzNDUxMzE1MTZiNTQzMTBmMzQi_pc
Please allow us some time. We will get back to you with an update soon.
Neeraj Agarwal — Reply ·
This issue should be resolved now.
It happened due to an issue from our side. We have resolved it now.
boton3671 — Reply ·
thanks a lot for quick response. Thanks for the support :)
