Recipe automation issue
Status: Closed · Asked by lologroso on · 0 views
Hi I want to automate the recipe creation on my wordpress website, it's working but I want to add the recipe schema with the recipe so how can we do that we pabbly ?
Hey @lologroso
Can you please elaborate on your use case briefly with the help of a short recorded video? So, that we can look into it.
Yes sure, I will set up a screenshot to show you what I want to automatize with Pabbly in addition of the recipe.
Here the schema mark up that I want to automatize coming from the plugin schema pro. Or maybe there is another technique to fill up these schema for recipe for all imported recipes ?
BR
Loic
Sorry, to say but unfortunately their API doesn't support custom fields. So, your use case couldn't be possible.
