reference data from the previous steps in code by pabbly
Status: Closed · Asked by kleine2 on · 0 views
kleine2 — Question ·
When using the code by pabbly, how can I reference data from the previous steps in my javascript? Because, when I just using the regular mapping, it looks like it's taking the static value from the test run and not the actual value when it actually runs.
I was told by Fegun in the FB group to share the workflow name because it doesn't seem to be working right. I uses the static values as input not the mapped values.
Workflow name:
Procrastination Profile To Google Sheets + Vbout
Have you checked your history log if your getting the same data from your Webhook response in live execution?
kleine2 — Reply ·
Yes, I've check the history and it's not working properly which is why I am asking for help.
kleine2 — Reply ·
never mind this is my mistake it's correct! Sorry.
