Request for Todoist Comment Integration
Status: Open · Asked by Adam Prettyjohns on · 0 views
Hi Team,
I'd like to put in a feature request please to have Todoist "Comments" functionality added to the platform. I'd like to be able to undertake an action when a new comment is added to the task.
The details from Todoist can be found here. I hope this is the right place to post!
Adam
Hey @adampj,
If there is a specific action or trigger event you would like to see integrated into the application, you can submit a request for it on this platform. - https://pabbly.hellonext.co/
After you submit your request, our integration team will review it and, if possible, add the desired action or trigger event to the application.
Hey @adampj,
If there is a specific action or trigger event you would like to see integrated into the application, you can submit a request for it on this platform. - https://pabbly.hellonext.co/After you submit your request, our integration team will review it and, if possible, add the desired action or trigger event to the application.
Hi Arshil,
Thanks for getting back to me regarding the Todoist Comment Integration.
Although it's a shame that the use case I was describing isn't possible, I do appreciate your help in clarifying this. I'll continue to explore other options. Also noted on the FR board, thank you... I was looking for this in this forum. Thank you!
Best,
Adam
