res 2 error - custom fields not found
Luv
Hey @amandatwg
After investigating your issue, it seems that the "Tag" field was entered in the wrong format. However, even when the data is correctly inputted, the problem still persists. We recommend using Lead Connector V2 instead of V1. Please set up your workflow with this version and let us know if you continue to encounter any errors.
Kindly refer to this video from 5:22 for further instructions -
