Resetting values
Status: Closed · Asked by gregsprock on · 0 views
I have set up a workflow and it appears after I deleted the testing rows in Google sheets it saved the values from the testing and is doing incorrect incrementation on this step. This is the data in the history for my most recent live submission. How do I get the steps to reset and refresh so new values are gathered from the spreadsheet?
The "Initial Value" is correct but 39+1 is obviously not 44, but 44 was the value I had gotten to during testing.
Hey @gregsprock
Kindly reconnect the Counter action step once and then try again. Seems like while setting up the Counter step you might not have reconnected/reset the value if used earlier.
Kindly try again after reconnecting the action step and try again.
