Response Received not correct
Status: Closed · Asked by harrisarshad76 on · 0 views
harrisarshad76 — Question ·
I am trying to connect my facebook lead ads with perfex crm, I made the connection but when I click on "Save and send request" and fill the lead form in Facebook developer tool, it's not showing correct.
I can see 2 fields all the time.
Please check screenshot
Its keep moving and nothing happen
Please help
Thank you
PabblyMember4 — Reply ·
Hi @harrisarshad76
Could you please again submit the test data and click on Save and Send test request button from the workflow and let us know if it helps? Also, you can watch the first part of the below video to integrate FaceBook leads Ad with Pabby connect.
youtube.com/watch?v=k8jZehG5EvE
harrisarshad76 — Reply ·
Same error it's not working.
Hi @harrisarshad76
I again check the data and it is showing correctly in your workflow. Kindly check again:-
