Responses in Pabbly not pushing to GoHighLevel LeadConnector
Status: Closed · Asked by MartinM on · 0 views
I created a workflow to connect OpenAI's ChatGPT with LeadConnector via SMS. I'm seeing all the replies back and forth inside of the Pabbly Workflow but they are not being sent to LeadConnector. I'm not getting any errors. Here's the link to my Workflow https://connect.pabbly.com/workflow/mapping/IjU3NmQwNTY5MDYzMzA0Mzc1MjZjNTUzNSI_3D_pc
Hey @MartinM
As we can see from your latest tasks history Id, we can see that the LeadConnector action step is performing fine.
I see the same inside of Pabbly but there is no SMS response pushed to my LeadConnector account.
thats crazy, I was just looking at your post and then I see your member name MartinM, i'm Martin M as well lol. sorry if this is off topic, just found it crazy. not very Likely.
Hey @MartinM
We deeply inspected your concern and it seems you are getting the SMS response from Lead Connector correctly.
By retrieving the response from the contact from its number Lead Connector is showing the response.
