Responses not returning in Simple format
Status: Open · Asked by cpacservices on · 0 views
Hello, I am having continuing issues with my steps such as Google Sheets and OpenAI and Grok and Gemini returning in the advanced format even when I select simple. The simple format is how we have our workflows structured so how do I go about fixing this?
Hi @cpacservices,
If you're on Windows, try pressing CTRL + Shift + R to perform a hard refresh in your browser and check if that resolves the issue. For Mac users, press Command + Shift + R to hard refresh the browser and see if that fixes your issue.
Arshil Ahmad
?Rate your support
This has not fixed the issue, this seems to be accross Pabbly with multiple apps. I have seen several forum posts about this.
We checked the workflow you shared and found that only the Google Sheets action step (step 8 within your route) had its response captured in Advanced format. We then selected the Simple response option and clicked on Save & Send Test Request, after which the response was successfully captured in the simple format.
https://drive.google.com/file/d/1OpMULxhzX1iX65ZQrV79p2ja_JZ9sANM/view?usp=sharing
Arshil Ahmad
?Rate your support
Thank you for your screenshare... I am not seeing it as you are showing me. Is there possibly something specific wrong with my account? I have linked a recording of it still not working for me.
Here is a link: https://drive.google.com/file/d/1kp85BsiTNnZV4cv5OnWeptgr7YY3kW_6/view?usp=sharing
Please log in to your Pabbly Connect account in an Incognito tab and then try to capture the “Simple” response.
Arshil Ahmad
?Rate your support
Thank you... is this the long-term solution or will this work via standard browsers in the future.
Hi @cpacservices,
Its just a cache issue and will work with standard browsers.
