Review Fetch Quota
Status: Open · Asked by Darryl Dahl on · 0 views
Darryl DHE — Question ·
Getting this on a GMB Review Response workflow I created yesterday. It does one review every 2 hours so it's only run like 10 times. How can it be "exhausted" already?
Hey @Darryl DHE,
Darryl DHE — Reply ·
Hey @Darryl DHE,
Email: [EMAIL]arshil.ahmad@pabbly.com[/EMAIL]
done
@Darryl DHE, I have taken note of your concern, and we appreciate your patience as we work towards a permanent solution for this issue. I kindly request that you allow us some time, and we will get back to you with an update soon.
it's working again though I had to go in and remap all the GMB review fields into later steps
It's still being a major pain and failing often, then magically starting again. Please see what can be done
Neeraj Agarwal — Reply ·
Hello Darryl,
We are planning to switch our existing function of Fetching reviews to Amazon Lambda to see if it would help to resolve this issue. We are estimating that it might take us around 4-5 weeks to get it done and fully transfer it on Lambda.
Until then i want to suggest that if you do not recapture any response in the action step of Fetch review, you won’t have to remap the values again.
Otherwise give us few weeks.
