RSS by Pabbly, RSS Feed does not work
Status: Closed · Asked by oroettger on · 0 views
Hi, I just moved from Zapier to Pabbly connect. But I have problems with two rss feeds, that work perfect in zapier but not in Pabbly.
Feed that does not get a valid response in Pabbly : https://ris.langenhagen.de/ri/si010_e.asp?selfaction=ws&bid=654&template=rss1&xsl=rss&rss=1&sid=fcb52b2c55b526985c8d4d6a225ed880
workflow: https://connect.pabbly.com/workflow/mapping/IjQ3NzYyNSI_3D
2. Feed that does not get a valid response in Pabbly : https://ris.hannit.de/personal/rss/sifuture?bid=2000178&sid=36730aad9ff4dd5db8dff844633e022f
workflow: https://connect.pabbly.com/workflow/mapping/IjQ1MDE2MCI_3D
as well, in zapier it is possible to access rss feeds, that are secured with username and password. is there a plan to integrat this in pabbly as well?
as well this feed does not work: https://ris.hannit.de/public/rss/sifuture
workflow: https://connect.pabbly.com/workflow/mapping/IjQ4MDUwNiI_3D
Hey @oroettger
Kindly allow us some time, we are currently looking into it. Shall notify you with an update soon.
It's taking a bit longer than expected, but we'll update you as soon as possible.
Your patience would be highly appreciated.
We have made some changes to our RSS feed module and now its working.
Please checkout your workflows:
Only the password protected feed URLs are not supported by our module for now. So, you won't be able to use that feed URL in the Pabbly Connect.
I hope you understand.
We have made some changes to our RSS feed module and now its working.Please checkout your workflows:
https://connect.pabbly.com/workflow/mapping/IjQ4MDUwNiI_3DOnly the password protected feed URLs are not supported by our module for now. So, you won't be able to use that feed URL in the Pabbly Connect.
I do understand the password thing. But in Zapier it is possible to pass login credentials. but anyway, the unprotected feed is working now. Thank you.
But there is a minor thing. It has to do with German special letters.
Feedexample:
Baustellenführung Neubau Gymnasium
Datum: 24.08.2022, Uhrzeit: 17:00 - 18:30
Raum: Theodor-Heuss-Straße Langenhagen Langenhagen
https://ris.langenhagen.de/ri/si010_e.asp?YY=2022&MM=08&DD=24">Zum Sitzungskalender...
Baustellenführung is displayed as Baustellenf�hrung
and Theodor-Heuss-Straße is Displayed as Theodor-Heuss-Stra�e
is it possible to correct this? i guess it will happen with these letters : ß ä ö ü and as well Ä Ö Ü.
That would be great! Thank you very much!
We have checked the RSS feed XML : https://ris.langenhagen.de/ri/si010_e.asp?selfaction=ws&bid=654&template=rss1&xsl=rss&rss=1&sid=fcb52b2c55b526985c8d4d6a225ed880
It seems the XML is encoded with ISO-8859-1 instead of UTF-8 that's why you are getting the characters like that.
We will check the possibility for required conversion at our end and will get back to you soon.
We have checked the RSS feed XML : https://ris.langenhagen.de/ri/si010_e.asp?selfaction=ws&bid=654&template=rss1&xsl=rss&rss=1&sid=fcb52b2c55b526985c8d4d6a225ed880It seems the XML is encoded with ISO-8859-1 instead of UTF-8 that's why you are getting the characters like that.
That would be great, as i have no pssibility to change the RSS format
