Rss feed step -regarding
Status: Closed · Asked by karthick on · 0 views
Hi sir,
We have tried pabbly rss step , but which is not fulfill our requirement .
Why because?
we have used the following rss feed url: https://www.instanews.city/india/feed
In that feed url response output has image and tags tag but when we use this url in pabbly rss feed step, we have not received image and tags tag.
so kindly do the needful to us .
note: when we use zapier for rss feed step, we have received image and tags in response output
Can you share the screenshot of how it's appearing in your Zapier workflow?
ok sure, herewith i have attached zapier screen shots output. kind your information.
We are checking on your concern and shall let update you soon.
I would like to know status about Rss step in Pabbly.
We have checked this with the technical team and currently, we don't support fetching images and tags with RSS integration. We have noted this requirement and should support this as well in the future when we will be updating the RSS integration. We shall notify you once we start supporting this.
ok sure thank you.
kindly update this sir.
ok sure thank you.
I would like to know the status about this .
It will take time. We cannot provide you with an ETA as before deploying any new update in existing integration, it takes a lot of testing and compatibility test.
As informed earlier, you shall be notified once we start supporting fetching images and tags with RSS integration.
Hi sir,
We have some doubt number format in spreed sheet formula, we think spreadformula working was wrong,
for instance, we have tried below
https://connect.pabbly.com/workflow/mapping/IjM3MDU3MyI_3D
In this workflow we have used number formatter, we have used subtraction of two rows value from get rows step of our google sheet but the reponse result was wrong .
we have tried before same formula in existing workflow:
https://connect.pabbly.com/workflow/mapping/IjE2Njc2NiI_3D
in this workflow number formatter in spreadsheet formula is working fine then why we have tried this in
https://connect.pabbly.com/workflow/mapping/IjM3MDU3MyI_3D , we got error kindly do the needful to us,
when manulay give data like 1000-500 in spreadsheet formulas we got response 500 but if we used reponse received variable we got error. kindly do the needful to us.
Hey @karthick
We have already replied to your above query on your another thread. Please check that out.
https://forum.pabbly.com/threads/spreadsheet-formula-in-number-formatter-issue-regarding.5520/
ok sure sir.
