Running automations for past triggers
Status: Closed · Asked by fisto on · 0 views
Now that I have a working automation, how can I run it for past events?
I would like it to run for the same trigger over the previous 90 days.
Now that I have a working automation, how can I run it for past events?I would like it to run for the same trigger over the previous 90 days.
You cannot fetch the older data as you're looking forward to doing. The workflow will run for the current event that will happen.
