Running out of operations
Status: Answered · Asked by Scott Bousfield on · 0 views
Hi Scott,
Thank you for reaching out.
Yes, if you have purchased a Yearly or Lifetime Deal (LTD) subscription of Pabbly Connect, your allotted tasks are reset on the 1st of every month.
If you anticipate exceeding your current monthly task limit, you can purchase an additional monthly or yearly task plan to increase your available task quota.
Monthly Add-on: Ideal if you need additional tasks for a particular month due to temporarily higher workflow activity.
Yearly Add-on: Suitable if you consistently require additional tasks over a longer period.
Additionally, you can track your task consumption and identify which workflows are using the most tasks by following these steps:
Log in to your Pabbly Connect dashboard.
Click on History in the left-hand panel.
You will find two options:
Task History: Allows you to view individual task executions and their consumption.
Task Usage by Workflows: Shows the task consumption of individual workflows, helping you identify which workflows are consuming more tasks.
Since you mentioned that your workflow activity was unusually high recently, reviewing the Task Usage by Workflows section should help you identify the workflows responsible for the increased consumption.
I hope this clarifies how the monthly task reset and additional task plans work.
If you have any further questions or need assistance, please feel free to let us know. We will be happy to help.
Soumya Tripathi
Customer Support Lead
🌐 Pabbly.com
🎉Black Friday Early Access
