Salesflare Help!
Status: Closed · Asked by Kingtony9 on · 0 views
I am trying to set up a workflow with salesflare. I am not sure if this is possible, but I did see it possible in pipedrive. So I am trying to replicate that.
So when I create a contact in salesflare -> I want it to create a google contact (easy)
but then when I UPDATE a CONTACT on Salesflare...-> I would like to update the google contact as well.
Currently, it doesn't have "Update Contact" on salesflare. Can anyone help me out?
Hey @Kingtony9
You can post the request to add the desired action event in the Salesflare Integration on the platform here - https://pabbly.hellonext.co/
Our integration team will look into it and include the action accordingly.
