Salesforce connection custom fields
Status: Open · Asked by Eskinder Assefa on · 0 views
Eskinder — Question ·
I am trying to create a contact in Salesforce when a new booking happens in Bookeo.
However, I am only seeing a few Salesforce fields:
--I don't see the custom fields in Salesforce that map to the fields in Bookeo
--I don't even see standard fields like State/Province.
How do I retrieve these Salesforce fields in Pabbly so I can map them correctly with the Bookeo fields I see?
Hi @Eskinder,
Please try using the 'Salesforce: Create Record' action event. That should provide you with access to the custom fields
Eskinder — Reply ·
Hi @Eskinder,
Thanks, Arshil.
I am now receiving an error due to a multi-pickllist field in Salesforce. How do I bypass this field (rather than delete it in Salesforce)?
Eskinder — Reply ·
Just so you know, the error message I am getting is "Cannot deserialize instance of multipicklist from START_ARRAY value [line:1, column:585]"
It won't let me save and send the response until this is resolved.
  1. Could you please state which field is a multi-select field in your 'Salesforce: Create Record' action step?
  2. Also, please state the format in which you enter the Start Date in your Salesforce account when creating a contact manually. Share a screenshot of the same.
Eskinder — Reply ·
Hi Arshil -
the multi-select field is called "Contact Type"
The date format is mm/dd/yyyy
I have attached screenshots for both
The issue appears to be related to addition of Start Date in your 'Salesforce: Create Record' action step. You can skip a multi-select field by enabling the mapping button and clearing the field. I made those changes to your action step, and it appears to be working now.
