Salesmate.io - Custom fields not accessible in Pabbly Connecy
Status: Closed · Asked by LaundryEZ / Go Get Laundry on · 0 views
When I run a search contact or deal, the only data that appears is minimal at best. I am unable to see any of my custom fields, and that is the data that I need to build my workflow. Is there another work around for this? I am moving away from Zapier, and you can see all the fields on their platform, no problem.
Thank You
Hey @Devin Morris
Kindly provide us the workflow name in which you are getting issue?
So we can check on it and guide you further.
I deleted it, because the data from Salesmate is so limited. I will be using an API call.
No problem. Could you please confirm if your issue has been resolved, or if you need further assistance?
I will have to figure out how to create an API call, so yes my issue is resolved. Thank you.
