Saw an option to create Workflow using AI Prompt! But then it disappeared :-(
Status: Open · Asked by avisin on · 0 views
avisin — Question ·
Consent to Access & Modify: I don't authorize Pabbly Support to log in to my account.
Did anyone else see an option to create a workflow using an AI Prompt? It popped up for me...and it actually worked really well. But now that option seems to have disappeared.
I hope it comes back, this would be an incredible feature for Pabbly Connect.
p.s. Did anyone else get a chance to try this out?
Hi @avisin,
Thank you for sharing this and for your interest in the AI Prompt–based workflow creation feature.
Yes, you are correct — this feature was made available briefly as part of an early rollout. Currently, it is undergoing further optimization and improvements to ensure better stability and accuracy before being reintroduced.
Once the feature is ready and made available again, we will be sure to inform you. We truly appreciate your feedback and enthusiasm, as it helps us prioritize enhancements that add real value to Pabbly Connect.
Thank you for your patience and support.
