Set Timezone in settings does not work?
Status: Open · Asked by Anders Nielsen on · 0 views
Anders Nielsen — Question ·
I would like to use the Denmark, Copenhagen timezone. However I have set it but it does not apply. I still have to set times in n UTC +0? How can i fix this?
See the screenshot please.
Hi @apps,
The time set in the Scheduler takes the selected timezone into consideration. For example, if you set your timezone to Europe/Copenhagen and the time in the Scheduler is 10 AM, then your workflow will trigger at 10 AM Copenhagen time.
You don’t have to set the time according to UTC; you can set it according to your own time zone.
Anders Nielsen — Reply ·
Hi @ArshilAhmad
Thanks for the quick answer! What you describe is exactly what I expected, but I set the flow above to run at 18:05 Danish time (it was 18:03 when I did it Danish time). However it did not run at 18:05 Danish time. Instead to get it to run at 18:05 Danish time I had to set it to 17:05
So it did not use the setup timezone despite what the note says in your screenshot. And you can also see on my first screenshot, you can see that the "date field" is different from the "local time" field.
The Date field will show the time in UTC format. The Local Time field will show the time your workflow will trigger according to your timezone.
Based on your Task History, we can see that your workflow hasn’t triggered yet. Please wait for it to trigger once, and if it doesn’t trigger at the correct time, do let us know.
