setTimeout() replacement
Status: Open · Asked by Yaniv Kirshon on · 0 views
Yan — Question ·
Consent to Access & Modify: I don't authorize Pabbly Support to log in to my account.
Hi there,
now that setTimeout() is restricted (since 2nd Feb), what are the alternatives to create a delay for seconds?
So far, a code step was my only option to create this...
I know there's the delay app (pabbly), however it doesn't support seconds units - only minutes, hours, days etc. So it's not an option.
Would you add an option for seconds as a unit in the delay app?
otherwise, what are my options for having a few seconds delay?
Thank you
Hey @Yan,
You can use this JavaScript code instead:
const delaySeconds = 20;
const start = Date.now();
while (Date.now() - start < delaySeconds * 1000) {
// wait
output = [{ wait: delaySeconds + " seconds" }];
