Shopia Integration Not Showing Writer Options
Status: Closed · Asked by Henry Hoe on · 0 views
Previously it allow me to choose the different writers, not it's not. Please check and fix asap.
Hey @decisivemarketer
Seems like you might not have connected your Shopia account correctly or might have permission to access the writers in the action step from your Shopia account.
And check whether the writer is present in your account.
Hey @decisivemarketerSeems like you might not have connected your Shopia account correctly or might have permission to access the writers in the action step from your Shopia account.
I've found the problem. The API token keeps expiring after a short period of time. Can you please fix it.
We have forwarded your concern to our technical team and they are currently looking into it.
We got a reply from our technical team that their application team integrated the integration the platform.
So, we would request you contact them once so that they will make the required changes as needed in terms to keep the refers the connection after a specific interval of time.
Hey @decisivemarketerWe got a reply from our team that their application team integrated the integration the platform.
I have reached out to them. But can your team do the same as well?
Hey @decisive
We recommend contacting our users as a priority as they will look into their paid users' concerns first.
