Shopify Add Product to MailerLite email automation
Status: Closed · Asked by strangeworldrecords on · 0 views
strangeworldrecords — Question ·
Hi there,
Does anybody know if it's possible that when I Add Product in my Shopify to have it automatically appear in a MailerLite campaign?
I would need multiple products to appear in the same email campaign before I send to customers and the product description needs to be included, plus a link to the item. I don't care about the price being visible.
Here's an example of my newsletter, which I currently put together manually but would like to automate:
Thank you for any help provided!
Richie
Hey @strangeworldrecords
You can try building a workflow something as shown below. Note that you cannot merge all products details in one email campaign as you're looking forward to do -
strangeworldrecords — Reply ·
Hi and thank you for your reply.
By "Note that you cannot merge all products details in one email campaign" do you mean one Instagram post would result in one email campaign?
That would not be any help. I would end up sending x 20 emails to my customers per day!
Yes that means one Instagram post would result in one email campaign and so on.
Okay. Not a suitable automation then.
