Shopify connection not pulling products
Status: Closed · Asked by xblindxx on · 0 views
I recently had to get rid of my old shop because of an app billing issue, luckily it wasn't too full of products yet.
This meant redoing the pabbly connection. The old one worked fine and pulled all digital and physical products, but the new connection (API Token etc) is not pulling the products into pabbly so I can set the trigger. I have retried so many times, and I am not sure what I am missing. I do need help with this if at all possible. Thank you
Hey @xblindxx
Kindly refer to the following video to connect your Shopify with Pabbly. Let us know if that helps you out.
Ah figured it out thanks to the video! Thanks so much (i was typing myshop.myshopify.com instead of just "myshop" for subdomain
