shopify - no product ID found
Status: Closed · Asked by adik1008@ on · 0 views
I connected shopify but I cannot find product IDs, it's as if connection didn't work. can you help?
Hi @adik1008@,
The issue appears to be related to you not having permissions to fetch or view the Products.
https://community.shopify.com/c/shopify-apps/api-this-action-requires-merchant-approval-for-read-orders-scope/m-p/2020175
Please follow the exact steps given in the video shared below, establish a new connection with your Shopify account and see if that fixes your issue. (Skip to 7:31)
thanks for help, I tested it and getting this. can you help?
Could you please share the Workflow URL in which you have tried this?
Hello Arshil
I think it got fixed on it's own. can I ask you:
Is it possible to push thrivecart weekly/monthly subscription to Shopify?
or it just work for single orders?
I've tried with daily and it failed, but maybe because the timeframe is too short?
thanks Arshil!
Your query is being addressed on this thread.
https://forum.pabbly.com/threads/thrivecart-shopify-subscriptions.20264/
thanks
