Shopify to quickbooks help
Status: Closed · Asked by 3dreloaded on · 0 views
Hello, so I've created a web hook to make new customers show up in quickbooks and new invoices. How ever when a customer puts more then 1 line item into shopify to order it doesn't show up in an invoice on shopify. What do need to link. This is the error it showed.
Hey @3dreloaded
It appears that you have removed all the action steps after Shopify's trigger event from your Workflow, so we cannot say what data you have previously to pass the amount in it.
Hey @3dreloadedIt appears that you have removed all the action steps after Shopify's trigger event from your Workflow, so we cannot say what data you have previously to pass the amount in it.
Ok I will re-build it and send, I'm trying to get when a customer orders more then 1 line item in shopify to come over on the invoice in quickbooks. can you show me an example of how to map these.
So still seem to be getting the error, I have saved the coding in my profile not sure if you can go in and look at it or not....
I have 6 products, so people could possibly order 6 line items, trying to get it all set up to go to quick books.
Hey @3dreloaded
As we can see from your workflow you haven't mentioned any action step. Please share the workflow you have added to the action step.
