shopify to woocommerce products
Status: Closed · Asked by megashope on · 0 views
I try many times but the workflow did not work. some errors as below. Solve the issue, please.
Hey @megashope
You need to pass single quotes in your content on the description field. Though have made the changes for you in your workflow and it is working fine.
Kindly give it a try and let us know if that works for you.
Thanks, sir, it is working fine.
