Showing Please check input values for WATI Integration with specific message
Status: Open · Asked by Ansh Goel on · 0 views
ansh010 — Question ·
Showing this reason only for specific template and when I input my own number then it sends message
Hi @ansh010,
Could you please share the Workflow URL so we can look into your concern?
The issue usually appears when the WATI template has an incorrect format and/or when the template is not approved by WATI. Please ensure that the template is in the correct format and has been approved by WATI. If the issue persists, please get in touch with WATI's support team to gain a better understanding of this issue since the message originates from their end, and we do not have much information about it.
