Simple Response issues
Status: Open · Asked by AshPLF on · 0 views
Hello!
Recently simple response on has not been working properly. I have had to add an json extractor step where in the past I would not need to do this. Today I came across an older workflow that usually has no issues and discovered it was affected by this issue. I have to place a json extractor step since I could not get the output as a simple response. I am worried this will begin affecting other workflows. Can you please take a look.
Thank you!
Hi @AshPLF,
Your concern is being addressed here:
https://forum.pabbly.com/threads/value-format-simple-advanced-and-raw-do-not-work.34304/
Arshil Ahmad
?Rate your support
