Skip Action Problem with Route Module
Status: Closed · Asked by Zel Giron on · 0 views
Hi! I am having a big problem here.
We can't configure the "enable ignoring error" option for the route module in Pabbly. I need to make sure the route module will run even if there is an error. Thanks
Same here. All my workflows with or without a router were broken because of this. We don't know when to enable it. And too many scenarios to cause an error. Why not enable it for all steps by default instead we have to enable it for all steps one by one just for safety.
The router action step wouldn't get affected by "Enable Ignoring Error" but inside the route action step, you need to check for the options.
For more details on the options, you may refer to the following threads.
https://forum.pabbly.com/threads/skip-the-module-on-the-failed-step.14251/post-66870
