Small error in create person converation (Plutio)
Status: Open · Asked by Hermes on · 0 views
I can't map an id to the new conversation:
If I unmap it I can select the user, but I need to map an existing ID.
Hi Hermes,
Do you mean that when you select the Member from the drop-down it works fine but when you enter the member id yourself, you get the Response with an error in it as shown in the screenshot?
@Neeraj yes, I can select from the list and it works, but if I want to have a dynamic id it fails with the error in screenshot.
@Neeraj @Pabbly Team Can someone please take care of this
Hi Hermes, We are having holiday here today. Will ask my team to update you tomorrow.
Hey @Hermes
Could you please share the name of the workflow in which you are facing such a reponse?
I rewrote the workflow with api's, but I just tried another workflow and same response: step 7 https://connect.pabbly.com/workflow/mapping/IjEwMTI4MiI_3D
Hey @Hermes
Thanks for sharing the workflow. Please allow us some time to look over your concern, we will get back to you with an update shortly.
Thanks!
Hey @Hermes
We have done some changes and now you can map the field. Although we have tried it and it is working.
Please check this out -
