Smartsheet automation adds ' (Apostrophe) in front of all numbers
Status: Closed · Asked by Arctic Sammy on · 0 views
Hi Team!
I am using Pabbly since over a year but never figured out why this is happening. My automation adds a new shopify oder into multiple other apps, including Smartsheet. All numbers are coming up with a " ' " in front of the actual number, causing my sheet not to work properly.
I need to manually delete and enter the number again everytime the automation triggers a new line in my smartsheet.
Does anyone else have the same issue?
Thanks!
Kristina
Hey @Krusty25
Kindly share the workflow URL once in which you have tried the same so that we can look into it.
Hi Supreme how do I share the workflow URL?
You can just share the workflow Url in the next reply.
