SMTP by pabbly not listed in connection
Status: Open · Asked by Ambrose Chea on · 0 views
I seem to have not be able to find my SMTP connections. my settings for one of my connection has changed, however I can't seem to get to it to fix it.
Hey @teknikal
Can you please share the workflow URL once in which you have used the SMTP by Pabbly so that we can look into it?
If you want to make a new connection, you can do so from within your workflow as well.
As for why it's not showing up in your connection list, I will have this looked into by my technical team and get back to you.
i do not want to update all my workflows with new connections....that doesn't seem practical
Please allow us some time. We will have this looked into.
We've implemented updates on our end and the connection will now accurately reflect the connection to the applications.
