Solution for Resizing images
Status: Closed · Asked by Fabsnebula on · 0 views
Hi all, I would like to resize an image.
I am currently using Airtable for the database and would like to use Pabbly with SOMETHING to resize images.
Any solutions would be appreciated
Hey @Fabsnebula
You can consider using the Shortpixel app for optimizing the image - https://www.pabbly.com/connect/integrations/shortpixel/
hank you i will check it out. Does it resize ?
Hey @Fabsnebula
You can give it a try and you can also find the other application which might provide such a feature here - https://www.pabbly.com/connect/integrations/
Thank you. How do I find the right application when there is more than 800 Apps ? Is there no option to find an app by what they do. You can only find them by name.
Hey @Fabsnebula
You can search the known application here whcih do the resize work. You can also search the application first on Google which does such work and then checks the availability on the integration page.
Please look at the image provided. There is no app that appears when I search for resize - In addition, a Google search doesn't tell me if your system uses the other system.
Hey @Fabsnebula
The Pabbly Intergation page will show you the available application on the platform, it will not show apps according to the feature.
You can first select the application which does your specific work and then search the application on the Integration page if the application seems available then you can use it in your workflow accordingly.
