Solution to count number of rows
Status: Open · Asked by arsachdeva on · 0 views
Hi
Is there a way to count the number of rows in a sheet within a pabbly flow.
For example, I fetch all the rows in a flow using Get Rows action and then can I find how many rows were there in the fetch in the form of number, say 15, 25, 100 ?
Is it possible?
NOT Related to a particular flow. Just exploring if this is possible.
Hello @arsachdeva,
Yes, this is possible. You can count the number of rows fetched from Get Rows in a few ways:
- Use the “rowIndex” of the last row returned by the Get Rows action — this directly reflects the row count.
- Capture the Get Rows response in Advanced Format, then:
- Use a Code by Pabbly step to count the number of objects in the array, or
- Use an Iterator followed by a Number Formatter (Counter) to increment by 1 for each item.
The final counter output will give you the total row count.
Either method will allow you to get the exact number of rows.
can we use Number formatter counter to control matching response number (i.e.1or 2 msgs.) chaflow messages when we get more match responses? I mean can we send only one or two msggs instead of all matched response?
Could you please elaborate a bit more on what you mean by a “matching response”?
Arshil Ahmad
?Rate your support
