[solved] Anyone having problems connecting to WooCommerce REST API?
aoris
Hi, I have been trying to connect to WooCommerce using the API keys and for some reason, the workflow keeps telling me that:
Warning​
Invalid Credentials or Website Url
The keys are copied and pasted, so I don't see where I could go wrong. And for the site, I've tried https://mysite.com, https://www.mysite.com, www.mysitecom, mysite.com... none would work. Any tip or same expereience, please? Thanks!!
Pabbly
Administrator
Warning​
Please try now. It should work fine now.
aoris
Unfortunately my hosting supplier (Ionos) has blocked the Woocommerce REST API which means that it simply won't work. I've managed to connect to another account (different hosting) and it worked fine. Good thing to know for Ionos clients.
Thanks for your help!
