[SOLVED] Platformly Segments and Tags
Status: Closed · Asked by phil on · 0 views
phil — Question ·
Would it be possible to add to the Platformly "Add Contact" also a "Segments" and "Tags" field?
As it is now, we have to use 3 steps, to simply add a contact with these parameters.
Pabbly — Reply ·
We're checking the possibility to add this.
Will keep you posted!
Pabbly — Reply ·
We have made the update. Now you will be able to see the "Segments" and "Tags" fields as well.
phil — Reply ·
Simply amazing! Thanks a lot.
